Billet Rear Suspension Kit (trail Arms)
cmw1100
dubai
Has anyone upgraded to billet rear arms from stock. Been drooling over Kibbetech for a while now.
these?
cmw1100
cmw1100
dubai
these?
Oh yes. But on the pricey side though 😬. But I’m already envisioning Powder coated flame red arms
We do have our own Billet Rear Suspension Links coming soon. Design is done and building has begun. A little teaser.
Dannybandaids
Michigan
Any benefit to running these? I know it helps wheel hop/axle wrap/articulation on regular trucks but do you still get these benefits on a TRX that’s purposefully built to handle these issues?
The joints are WAY better on these. No deflection in the joints which does help with the wheel hop, axle wrap, and articulation as you mentioned. The suspension will move up and down through articulation much smoother as well. The joints will also last longer and are easily replaceable if they ever need servicing
Nat.G
mesa, arizona
Im still drooling over these ones from FMI. The machine work and components are high quality. i got both upper and lowers for $3,400. but you can get lowers for $1,900 on the FMI website depending on what you're wanting. i got instant gratification as soon as these were installed. I had more control and connection with rear. It has 17-4 Stainless steel heim spacers, 1" Uniballs from FK, the custom machined 17-4 stainless spacers are designed to fit in the stock mount locations. The front mounts also have a Delrin wobble stopper to keep the arms in alignment. The Upper arm also has a 17-4 stainless post for the suspension travel sensor to ensure the truck will work correctly. This kit is pretty legit IMO
Lowers
Upper & Lowers
Same connection points as ours. Same materials as well.
One of the things that sets ours apart is the UHMW Skids on the bottom of the lower links. We want to protect our investments and thought our customers may want to as well.
Outofmyleague
